Hello Marq customers,
Our next beta version for the MARQ Series is now available!
The beta below is not compatible with MARQ Aviator.
Instructions for installation are available below the change log on the above page.
20.00 Change Log Notes:
- Added ability to turn off recording an activity during a golf round.
- Added an alert to notify user when battery is critically low during a music sync.
- Added HRV Support from chest strap for Yoga and breathwork.
- Added pop-up to Pulse Ox Measuring feature if the device detects too much movement and cannot get an accurate measurement.
- Added support for new biking activity profiles: eBike, eMTB, Cyclocross, Gravel Bike, Bike Commute, Bike Tour, and Road Bike.
- Added support for the HIIT activity profile and workouts.
- Added support for the Pickleball profile.
- Added support for the Padel profile.
- Added support for the snowshoe activity profile.
- Added support for the tennis activity profile.
- Added new tips to indicate which activities support Incident detection.
- Improved accuracy of Surf wave count algorithm.
- Improved Explore Sync app waypoint load times.
- Improved Lactate Threshold and Altitude Acclimation algorithms.
- Improved measurement loading UI when taking an SpO2 measurement.
- Update the altimeter’s auto calibration to be either be “On” or “Nightly”. Setting to “On” will calibrate at night, activity start, and continuously during activities. Setting to “Nightly” will set the device to only calibrate altitude at night.
- Fixed issue with alarms intermittently not going off when the device is set in Max. Battery Mode.
- Fixed display issues on the device after navigating to a point initiated by the Garmin Explore App.
- Fixed issue where selecting a single point on a map that contained multiple items would not display the items properly.
- Fixed issue that would corrupt open water swim activity files.
- Fixed issue where PacePro bands would not be recognized by the device.
- Fixed issue with updating aviation data over wifi.
- Fixed issue with activities reporting incorrect Activity Calories and Training Effect data.
Current beta peripheral software version numbers below. New versions are indicated in red.
GPS: 5.30
Sensor Hub: 11.01
ANT/BLE/BT: 6.11
Wi-Fi: 2.60
Please note, the beta updates released on these forums are not compatible with APAC region devices.
Please send all bug reports to [email protected], and indicate which model of the Fenix 6 Series you have in the subject line.
