Bug with Data field 5 & 6 and ConnectIQ field
I'm having an issue using a ConnectIQ Field in Data field 5 or 6 on my Garmin Marq Athlete under the Run or Treadmill function (have not tested other activities).  The ConnectIQ data field I'm trying to use is Stryd Zones (for calculating power with the Stryd foot pod).  If I try to enter it Field 5 or 6, it shows up as Timer but it still uses 1 of the 2 available ConnectIQ Fields.  However, if I enter it in Field 1-4, the field works correctly and shows as Stryd Zones and not as Timer.
I've had this bug in the past on the 4 data field screen where at random, the Stryd Zones ConnectIQ field (or the old version called Stryd Power Connect IQ field) would on occasion spontaneously change to Timer while continuing to eat up 1/2 ConnectIQ fields.  I was able to solve it by restarting the watch and recreating the data screen.  It was annoying but it worked (Garmin Marq and Fenix 5s Plus).  Anyone else come across this issue with other ConnectIQ fields (non Stryd related)?
  • I see the same issue for Stryd Zones as well as for Garmin own Running Power data field
  • I had a very similar issue on F6X recently (MARQ's been always fine). Removing the Stryd data field from screens, uninstalling it, soft-resetting the watch (hold the light button for 15 sec until the watch shuts down), and installing it again seems to have fixed the problem.
