MARQ Aviator crashing / restarting
Greetings community,
I am having an issue with my new MARQ Aviator, just over a week old. Previously I owned a Delta / Charlie so I am familiar with the interface and functionality.
Here is the issue:
When using Navigate - > Flight Planning - > Find Waypoint - > Search by Ident.
After entering an airport identifier (for example, CYYC or YYC but I also tried many from around the world), the watch immediately restarts and the startup screen is displayed.
No software updates available through Garmin Express. I reinstalled all the maps and reset the watch to defaults, issue persists.
Contacted Garmin support via email, was told it would take 5-10 business days for a reply.
Do I have a defective unit? It would not make sense for a flagship device to be shipped with such a serious software bug.
Could someone kindly try the above on theirs and let me know what happens.
Thank you all in advance for any help & advice.
  • Is the MARQ Aviator not supported by Garmin Aviation? If not, that is a serious strike against the MARQ device as Garmin' Aviation Support group is really quick with support requests, especially if you contact them via business hours and over the phone.
    0 Former Member in reply to dbrobert
    That is a good point. Though judging by the disclaimer "not to be used as primary means of navigation" maybe it isn't.
  • Yes, I am having the same issue. However, it does not crash if used within the Fly app (Fly app, select navigation under options).
  • Happened to me on my D2 delta yesterday. It restarted and then I worked
    0 Former Member in reply to Mike72
    Installed the 3.33 firmware with no resolution for this issue.
    0 Former Member in reply to Garmin_ODQA
    Good moring,
    I have a Marq Aviator snice August, ans it crasshes continuously. I have detected that this happens if I install any wacth face downloaded from the connect store. His last time I deleted everythign and configurate as new, and in two days I didnt have any crash. IN any case makes no sense that i cannot install watch face to avoid continuous crahses (it crashes and crashes when it restars....).
    Any help?
    thanks in advance!
