Hi
I’m trying to sort out the altimeter issue and I want to install an old system software, < v10, with the previous sensors firmware,v1.5 to check if the barometer is behaving better.
does anybody has it?
thanx!
Hi
thanx!
I have some old versions, but im not sure how to pass it to you. Any preferences? You can give me an email address for example.
regards,
marek
Thank you marek!
can you upload them there?
Sure. I uploaded all I had
thank you marek!
that's wonderful! I asked yesterday to Garmin support and they were not able to get these files..!
I added 1.50 and 1.60
grazie!!!
I added what I already had, thank you to everyone for the quick answer!
Show off your best result.
It was already good. It has to be found now.
Hi!
I gave it a try by going back to sensor hub 1.5 and system software 14.4
unfortunately, the barometric diagnostic screen is always wrong, it marks an incorrect altitude of almost 900mt, so the error is already there.
my conclusion is that there is an error in the altitude calculation algorithm, perhaps at the sensor hub level.
In older versions of the system software (<16.5) the calibration algorithm was still able to compensate for it, and the error is evident only when the watch is restarted; after the first calibration, for example when starting an activity, the calibration works and is maintained.
With versions after 16.5 the calibration logic is different and does not compensate for the error, after a few seconds the altitude value is the one calculated by the barometer, in my case much higher than reality, maybe because the GPS altitude is too different from what calculated by the sensor I suppose.
when I start an activity auto calibration is done and after a few seconds the altitude goes up and offset both altitude and elevation gain.
However, I noticed that, even with the latest version, if you use only the barometer, turning off the altimeter, the pressure value is correct for many hours (I compared with another watch).
on the other hand, if you leave the sensor on auto (altimeter and barometer) also the pressure will offset a few seconds after calibration.
now the word to garmin engineers, I have run out of ideas...!
