Poor GPS accuracy!
Hello, when you have a look at this activity: https://connect.garmin.com/modern/activity/8623907452
you will see on the map that the GPS Tracks is not on the track I ran. It is like this every time and it is *** annoying! The Pace is way off (at least it is way more constant than the graph shows!) due to the problem with the track!
I mean whats the *** problem here? Already reinstalled, restartet, layed it outdorrs for some hours in GPS Tracking mode...no change!
Any tipps or is it just "the waether"? Thanks!
Also when will we be able to see battery status in %? Cant be so hard right?
  • Try enabling GPS+Galileo, if you did not yet. It may perhaps help a bit. Also connect the watch over the USB cable to a PC with Garmin Express and sync there just before going out, to assure a problemless update of the EPO file. It tends to fails occasionally over the Garmin Connect app. And I'd also recommend restarting the watch.
