Getting Low Battery warning when plugging into AC adapter and watch won't charge
Lately, when I plug in my Instinct to the AC adapter to charge it, I'm getting a low battery warning, and once I clear that message, it appears to not be charging. None of the battery indicators indicate charging, and in fact the battery charge icon appears lower than when it's not plugged in.
If I plug it in just right and then don't touch it, I don't get the message and it will charge.
I only seem to have this problem when the charge gets down to 2 or 3 bars.
I was thinking it might be a problem with the charging port or cable being worn out, but when the battery indicator is at 5 bars (only slightly discharged) I don't get that low battery message and the watch immediately begins to charge.
I've seen a few other similar issues, but I haven't found anything quite like this.
Is this a software issue? Should I be more concerned about this?
Thanks,
John
