That temperature is the local weather temperature, not the watch's measured ambient temperature. You will need to add the Temperature widget to see the watch temp.
Which is what the discussion in the link I posted says, along with offering several options for monitoring the actual watch temperature.
You must be having a bit of a heatwave where you live!
(unless you use the Fahrenheit scale).
What you are seeing is the weather app that reads from the nearest weather station.
The get to the ambient temperature you can add the temperature widget. It will be affected by your body heat when wearing it.
That 40 celsius and yes we are having a heatwave.
