FWIW - if you’re using a Garmin instinct watch with an Alpha 100 or a Pro 550 Plus, check out the "dog tracking" feature. My watch downloaded a software update during the week. The dog track feature now points a 180 degrees off from the Alpha. The Alpha is correct. I’ve re-calibrated the compasses on both the Alpha and the watch. Both compasses match. Also, removed then added back the dog track widget and re-paired the devices. Finally, I reinstalled the software update to the watch. The Instinct watch dog track pointer is still 180 degrees out from the Alpha 100's.
Friends with Alpha 100's and Pro 550 Plus are reporting similar problems.
Info on Instinct watch:
- Software is up to date — Version 13.20.0.0
- Synced Sunday, Mar 21 at 12:58
- Serial Number: 5UM395036
The Alpha 100 software is up to date.
I reported the problem to Garmin customer service.
