Instinct with 10.10 Software - no more data is logged
Hi all,
since the 10.10. update no more data is being logged in Garmin Connect. No sleep data, no fitness data - nothing is working anymore.
Any help is appreciated.
Cheers,
Joerg
  • There are basically three possibilities:
    1. The synchronisation does not work (the white circle around the watch symbol never closes) - in that case follow the tips in the Sync / Connection Troubleshooting Guide
    2. When the synchronisation works (the white sync circle closes and turns green), but not all the data is appearing in your account, then it very probably means that your device is associated with multiple accounts, and a part of the data lands in the other account. It frequently happens for example when you reinstall the application, and inadvertently sign up a new account instead of signing into the original one. Follow the instructions from the support document Data is Missing from My Garmin Account After Syncing to resolve the issue.
    3. The storage (or the FIT file storing the HR data and the steps data) is dammaged or full. Try backing up and deleting old files from the folder //GARMIN/Activity and //GARMIN/Monitor.
    0 Former Member over 5 years ago in reply to trux
    Thank you very much for your quick reply.
    After I had wiped out solution #1 as Sync worked perfectly I tried solution #2 allthough I don't have multiple accounts. So solution #2 did the trick Slight smile
    Cheers,
    Joerg
