How to add coordinate page to a custom activity
Is there a way to add a page that shows coordinates in latitude and longitude and MGRS in an activity I’ve created?
the page I want to add is identical to the one found in the tactical activity, but I can’t find nothing similar in the custom fields
  • You can use
    Data screens - Add - Custom data - (Choose Field 2) - Navigation fields - Lat/Lon (or Location)
    The problem is, that if you use some small field, Instinct does not offer not Lat/Lon nor Location. (Probably because there is not space enough on the display for it). You could have it on two successive screens. Or you can set two-field screen, set Location on the Field 2, then switch to three-field screen, set Lat/Lon on the Field 3. I do not know how to set it on the Field 4, so the result is not exactly like in the Tactical activity:
    Settings-System-Format-Pos.Format-Format can change location to MGRS format.
  • Only god knows how many times I’ve passed all the menus without noticing this option! Really thank you! The only problem is that also if I have mgrs it shows lat/long, but it’s not a problem! Thank you again
