I did master reset using this instruction movie and it works,
but now i need to set-up everything again,
i hope i will not happen again
That's the exact purpose of the Master Reset - to reset everything to the original state. And that's why it is often referred to as Factory Reset.. So of course, it will and should happen again, that the settings will be reset when you do the Master Reset.
If you had saved backup files, the master reset would not be so painful.
Courses and Activities can be copied as usual files, not over the NewFiles directory. Schedule.fit probably saves alarms.
Only Widget list and some settings from MENU-Settings-System is necessary to set again manually (Hot Keys for instance).
