Hello everyone
I've been a very happy Instinct fan so far but after the last update I find the altimeter not to be working properly.
I've been triying to calibrate both the altimeter and the barometer following some of the advices I've found in this forum but unfortunately I've not solved the problem: the altimeter seems to be constantly adjusting itself to the wrong data. Even when I spend some time at a "known" altitude (I live at 40 m asl) the altimeter keeps fluctuating between negative and positive datas rather than staying at the same altitude showing a flat line with no changes. No matter how often I manual calibrate it or turn the auto-calibration on or off, it keeps fluctuating. It is so bad to the point it affects the overall number of daily climbed floors: when at work, for example, the watch sometimes counts floors even though there is not a slight change in altitude.
Not to mention the problems I've had when recording activities. It pretty much shows the wrong data all the times.
Any advice? Is anyone having the same issue?
Thank you in advance!
Nick
