Hi.
Finally got the update but step graph has gone. I know from here there was an issue with stepts before full release but assumed it'd been fixed?
Hi.
For me it is the same after 7.0 and 7.2 I hope this error will be corrected
Error still test, no graphic display of steps after 5 p.m., as if it had crashed
Having this same issue - watch face froze and the time stopped updating until I opened a widget and went back to the main watch face. Step graph on watch face has been blank since then, although the number of steps appears.
Hey I was having the same issue with my instinct not showing the steps graph. I did some research and learned that if you hold the CTRL button until the screen turns off and wait a few seconds and hold the CTRL button again you’re watch will turn on. This is a way to restart you’re watch fixing any glitches. After doing this my steps graph was working normal again. Hope this helps
I had the issue now
Unfortunately, this method doesn't work
