Hi,
I've recently bought an Instinct and took it for a hike.
I also use Locus Map so after finishing I usually export the GPX files from the Connect app to Locus.
However there are some differences:
Garmin Connect / Locus imported
Distance: 15.58km / 17.76km
Elevation gain: 673m / 692m
Tracking time: 5:24:01 in both
Moving time: 4:00:45 / 4:48:33
The distance and moving time is quite considerable.
I checked with Locus Support add they say data shown in Locus is unfiltered and as such should be correct, and suggest that probably there is a kind of filter applied to Garmin, hence the shorter distance (15.58km is shown on the watch as well as in Connect).
Can you please advise on this? I was using the Hiking profile with default settings and no autopause. We stopped often to take photos, find a way through streams, etc...maybe that's the reason?
GPX is here: https://help.locusmap.eu/attachments/18552?token=9a1cee8b067c848f02e08fc67c5afe60.zip
I had two other hikes where the values were about (but not entirely) the same. Also I went for jogging which was perfecly matching after being exported to Locus.
Thank you in advance,
Adam
