I have a Garmin Instinct watch.
I want to update to the 7.00 version (28 april,2020), but when i copie the files, i get a warning that there is not enough space on my device.
What can i do?
What can i do?
oke, well if nothing Works maybe i ll do a factory reset. - fingere crossed.
If installed 7.00v again- maybe it helps. W’ll see tomorrow why i cycle a course.
thnx 4 support
I had a closer look again at your activity, and compared the device info with mine, and see some differences. Everything is identical, but I have two more entries in the sensors section. I have twice the entry BLUETOOTH_LOW_ENERGY_CHIPSET, while you have nothing like that. Did you disable the Bluetooth on your watch when doing the activity? Normally it should not matter, but if there were a bug in the v7.00, the difference in settings could explain why I (and others) do not see the same behaviour.
If it is the case, and your activity was done with BT shut down, you could try doing the activity with BT on, to see whether it makes any difference.
My data:
{sku: "006-B3126-00", softwareVersion: 7}
{sku: "006-B3126-00", localDeviceType: "BAROMETER", softwareVersion: 7}
{sku: "006-B3750-00", localDeviceType: "GPS", softwareVersion: 2.6}
{localDeviceType: "ACCELEROMETER", softwareVersion: 249.56}
{localDeviceType: "BLUETOOTH_LOW_ENERGY_CHIPSET", softwareVersion: 654.7}
{localDeviceType: "WHR", softwareVersion: 3.32}
{sku: "006-B3127-00", localDeviceType: "SENSOR_HUB", softwareVersion: 1.4}
{localDeviceType: "BLUETOOTH_LOW_ENERGY_CHIPSET", softwareVersion: 327.68}
Your data:
{sku: "006-B3127-00", localDeviceType: "SENSOR_HUB", softwareVersion: 1.4}OK, I had a bit time, so tried it myself - did a two short running activities, one with BT shut off, and the other one with BT on. However, in both cases, the moving time and the speed were logged correctly. And although, when I turn off the BT, the sensor data then indeed looks like yours, it apparently does not cause any problems (at least not in my case). Still, you could try doing an activity while keeping the BT on, just to be sure.
wow trux,thank u verry much for the research. While reading your reply's, i think i know what it is...(my bt is always on)
During cycling , i use my BT headphones, so i expact my JBL causes the problem. Tomorrow i ll take a short ride, and see what happens.
keep u updated
I suspect it won't really help, but is is certainly worth of trying.
i did’nt work
why i cycle, my watch did not show the current speed also.
As I wrote, I did not believe it would help. I am afraid, you'll have to try the master reset.
i have done a reset ;(...
and ride my bike, did not connect Phone by bt... en still the speed isnt correct... during the activity i cant see the speed also.. it says {- - - -}in my watch screen..
In that case try reversing to the original version.
The software you mean? You have a link?
