I am curious if the TEMPE can be connected to an Instinct and GPSMAP 64st at the same time.
Does anyone know?
Thanks!
Best regards,
Fred
Does anyone know?
Thanks!
Best regards,
Fred
Yes. I have both a 64st and an Instinct. I can connect to a Tempe with both at the same time. It's the beauty of ANT+ vs. typical Bluetooth. Multiple devices can connect to same sensor.
I also often…
Same Tempe connected to Instinct and 64st. Temperature reading on the st is at the lower left of its screen.
Hi D_Estes! I picked up a Tempe and I like it!
There are two questions that have come up.
Can the temperature be added to the watch face? I went through the options and did not see it.
I expected the Instinct to always have a temperature but I find I need to wait. Does that should correct?
Thank you!
Fred
You can see the current and high/low temperature over the last 24hrs via the Temperature Widget. The widget will only display the temp once connected to the Tempe (could be up to a minute) for about 45sec before returning to the main face. The only way I know how to see the temperature longer is to be recording an activity with the temperature on one of the activity display screens. There is no way to see the temperature continually on the watch face.
