First run with instinct and when I checked map on completion it only showed half my run.
Did you wait for a GPS fix before starting the run?
Ok thanks just waited longer today before run
But now 2 different distances for same run
I assume the left run is the previous one, where the first half was not recorded, right? I suspect that for the part where GPS was not available the watch took pace and distance from built-in accelerometers, and in that case the distance is much less accurate. The watch just "guessed" the distance for the first half of the first run and this is why you see discrepancies.
