Since weather widget shows a temperature from the forecast source and not internal thermometer then where I can find the data from the sensor?
Well... the Temperature Widget is the easiest place to see the current and historical internal temperature from the onboard temperature sensor:
You can also see it with a Temp data field while in an Activity.
HTH
