I'm looking to set up my Garmin so it shows just the compass bearing And distance to selected waypoint. Like on the attached picture. I find the map very inconvenient for navigating to single waypoints, Can anyone advise me how to do it?
Thanks
Thanks
I was hoping there is a mode where the map isn't shown and I get to see a larger direction arrow, I use the watch on an off-road motorcycle and the having a large series to follow would be easier than…
In that case add a Custom Screen to the Activity settings. Choose the 2 fields screen layout, with the bearing in the ring field, and the distance in the main big field. It will look pretty close to what…
The photo in the opening post does not show a NUMERIC bearing.
That's exactly what was requested in the opening post. However, if you do it in the way I suggested, you'll have both the arrow, and the digital…
The default navigation screen shows the exact information in an Instinct layout that works the same way as the screen shot you showed does…
I setup to navigate to a Saved Location (single waypoint)…
Not much different than the screen you show? Distance and direction.
I was hoping there is a mode where the map isn't shown and I get to see a larger direction arrow, I use the watch on an off-road motorcycle and the having a large series to follow would be easier than looking at the map.
Is there a way to get an actual bearing number so that I could use my baseplate compass to follow a bearing?
Yes, there is - long press the ABC button (left bottom) and you get the compass and altimeter screen. Scroll up or down for several different screens, and chose the one you prefer.
Nope, that doesn't work either. All I want is a numeric compass course to our waypoint. It has to be here somewhere...
In that case add a Custom Screen to the Activity settings. Choose the 2 fields screen layout, with the bearing in the ring field, and the distance in the main big field. It will look pretty close to what is shown on the photo in the opening post (no map shown, as requested).
The photo in the opening post does not show a NUMERIC bearing. It shows an arrow on the watch face. A compass has 360 degrees. A numeric East bearing, for example, would read "90". Is the instinct capable of showing a numeric bearing to the next waypoint or destination, and if so, how does one get it to display?
That's exactly what was requested in the opening post. However, if you do it in the way I suggested, you'll have both the arrow, and the digital bearing (see the sreenshot below). If you do not want the arrow at all, select a different layout and put the bearing to any other postion than the ring-field. It will be then digitial only.
In the same way as any other custom data values - simply select it from the list of available values. These ones are in the Navigation category.
Excellent! Thank you.
