Automatic zoom on map
How does the automatic zoom function on map work?
I can't understand the difference between on and off.
While I am using navigator, It seems that it is always zoom in mode.
  • Hello, havent tried that on my instinct, but in other Garmin products what it does is auto zoom in/out depending on the speed you are moving.
    Check that out.
    Greetings.
  • Dear fmercado,
    Thank you for your information!
    Certainly, I always confirm the direction to point, while I am stopping at the corner.
    I will check it again while I am moving.
    Regards,
  • I checked zoom in/out on map again by using my car.
    Unfortunately, I couldn't see zoom in or out while I was driving. :(
    It was always zoom in.
    Should I have to set another option?
  • What I don't understand is why Garmin provides such high levels of zoom in.  The best zoom is 5m.  But Garmin seems to be forget that the zoomlevel and the accuracy of the GPS have to be compatible.  It happened already a few times that I wasn't at a crossing according to my watch because of the zoomlevel and I thought I had to go straight but actually I had to turn left or right.  In other words it's possible the road you're running on isn't showing on your watch.  I can set my watch on "stick to road", but that doesn't solve the problem of the crossing you're on or not.
