Software flaw - strength sets in multisport
Hi.  Is there a way to contact Garmin to get a software update to correct this issue?
Let’s say you are on the treadmill and recording that activity. When you stop, you ‘change sport’ to strength.  The strength activity starts, but it only records the actual set in the rest period as you need to push the set button one more time to start the set.
Using strength activity works fine if using it first in a multisport but not after.
  • Anyone else have the same issue or just me?
    Nobody with Instinct Solar (1st gen) has the same issue, because that model does not support the feature Change Sport or Multisport at all, as far as I remember. You may want to repost your query in the forum adequate to the exact model you own (Instinct 2, Instinct 3, or something else?).
    However, I guess that starting with the rest period in Multisport is by design, and makes sense. I doubt Garmin would change it, but you can always try requesting it at Share Ideas | Garmin
