I have just purchase a new Instinct Solar….. after one ride it shows a message saying memory almost full…. Why?
Well that’s wierd …. The device just updated itself so I tried a small walk test…. No memory message came up at the end this time. I did see once plugged in that the overall used memory had dropped by 0.15 mb…..The same test did so before the update. I will do a longer test and see what happens…… any input gratefully received. Sorry about the multiple posts but I wanted to give you all the info I could….. I am still concerned of this behaviour on a brand new device….
Where did you buy the the watch? Could it be pre-owned? A new watch definitely has much more free storage than that.
You can definitely delete the GCD file, if the watch was already updated. Also check the folder //GARMIN/REMOTESW/ - there could be another GCD file, that can be equally deleted. You can delete all activities from the folder //GARMIN/Activity/, if the watch was already synced (do it regularly). More free space can be gained by deleting all unneeded languages from the folder //GARMIN/TEXT/.
Hey thanks for the advice…… I will delete the files you suggested as I have just updated the device (well, it did it automatically)…Yes it was new fro Rebel Sport……. I did delete old courses on Garmin Connect and, even though they weren’t on the device, somehow this freed up a few mb of memory….
I suspect most of your issue was the gupdate file you noticed. You had a pending software update on your watch taking up the memory. After you replaced your existing software with the newest version, it freed up space again. You should be good to go.
Worth noting, if you often record long GPS activities, memory can legitimately become full. Ensure you have already synced any recorded activities to your Garmin Connect account and clear your Activity folder on your watch through your computer as needed.
When you clear the Text folder that Trux mentioned above, removing additional languages not needed also freed up more space on your watch.
