Hi all,
Instinct solar after start the activities the barometer and altimeter still the same, in suppose have change when I setting my barometer & altimeter in auto calibration right ?
Any help please?
Thanks
Hi all,
Any help please?
Thanks
You can manually calibrate your altimeter going into Settings > Sensors & Accessories > Altimeter if you are not seeing your altimeter move when you start the activity. You should also soak your watch in luke warm water for 5-10 minutes in case there is anything built up within your port causing any issues.
