After charging the watch to 100%, there is no green bar in the statistics. does anyone have the same?
to this I will add that after a few hours, 1% of the battery decreased.
I do not quite understand your behaviour - it is since two months that you post practically every single day several posts complaining about the battery of your watch. You've been advised countless of times to have your watch replaced, but you do not give up, keep the watch, and keep complaining how bad it is. It has a clearly bad battery, or another hardware defect, and your permanent moaning here on the forum won't change any slightest bit on it. Please go finaly back to the store where you purchased the watch, and have it replaced for a fully functional unit, and stop spamming this forum with your unfortunate story.
On Monday I will send this watch back for reclamation, I wanted to give it a chance, but after 2 days it has 83% of the battery, it is getting worse and worse, I used it during the run and the battery drops drastically.
forgive me for constantly returning to the battery of this watch, but I wanted to give it a chance but it hurts that it does not work as it should.
