Instinct Solar - 10.00 Public Release Candidate
Hello Instinct Solar users,
We have new beta software ready for your upcoming adventures! This is our public release candidate that is slated for release next week.
Please read the 'notes' and 'installation instructions' in the 'Updates and Downloads' page found in the link below. We look forward to your feedback!
Instinct Solar: https://www8.garmin.com/support/download_details.jsp?id=15394
Note: Please allow for the updates to propagate across all servers. There is no need to post that the link does not work. It will after a bit of patience.
10.00 Change Log Notes:
  • Version bump to 10.00
For those who want the full list of changes since our last public release (9.40):
  • Added support for viewing battery percentage in main menu.
  • Added support for viewing recovery heart rate from the activity paused menu.
  • Added ability to delete and reinstall language files on device (Menu > Settings > System > Language ).
  • Made improvements to Alarms and Timers.
  • Made improvements to Solar Intensity chart.
  • Fixed potential crash during navigation.
  • Fixed an issue where the device would intermittently fail to save an activity.
  • Fixed stress recording during Yoga activities.
  • Fixed issue with Hourly Alert setting when accessed from SET menu.
  • Fixed issue where map datafield was not visible after using pan/zoom.
  • Fixed issue with Sleep Pulse Ox setting when accessed from the Activity Tracking menu.
  • Fixed possible crash and reboot when powering down.
  • [Tactical] Fixed issue with Jumpmaster setup.
  • [Surf] Brought in Surf improvements.
For any issues that you encounter, please send an email to [email protected]. In your email please include the software version, and a detailed description of your issue, along with any steps to reproduce. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Hi, you are right that could be true.
    • Driving while watch is under a car windshield (they are known to negatively affect spectrum of sunlight)
  • I will conduct a few more tests, because for now it turns out that it is better to stick to the first generation garmin instinct, because not much has changed.
  • I hope this is not a way how you verify our problems with the solar charging : no changes have been made for this functionality.
    The only prof is results of tests and the customer reports.
    I've checked the solar intensity chart in GC. The sole intensity during my ride was from 50 to 100%. I'm collating it to similar but shorter ride. The solar charging looks broken.
    Please check it, test it. Do not answer that I'm just don't know what I see. The functionality should be not just marketing trick but reliable solution.
  •    j
    I am running a Tactical Instinct with beta firmware 10.00. With the battery on 10% and showing 7 days, I placed a powerful headlamp on to the watch face with the watch in battery saver mode and placed in water to dissipate heat. After 60mins, the solar graph showed full sunlight, and the watch increased to 12% and 9 days. There appear to be no issues with my watch running beta 10.00
  • I've checked the solar intensity chart in GC. The sole intensity during my ride was from 50 to 100%. I'm collating it to similar but shorter ride. The solar charging looks broken.
    Comparing to similar, but shorter rides is not a valid test. You should do the same ride, at the same time of the day and there should be the same amount of clouds in the sky. Also, you should wear the watch exactly the same way as you did before, as even the smallest change in angle will cause the bezel to cast a different shadow over the display witch affects charging a lot.
    As an example, I rode a bike on Saturday under bright sun. During the first 1/3 I was under blue sky with no clouds and no trees or buildings around at all. I was expecting to get 100% during that period, however this was not the case, as you can see on the screenshot below. Why? Well, I realized as I was going along the road, my body and arms (and the watch itself) were sometimes casting shadows over the display. Also, the display was usually not orientated towards the sun, because I was shifting gears, turning the handlebars and moving my hands in general, which affected the angle between the sun and the display.
    To my surprise, I got most sun power at the end, when I was back in the city and I was certainly trying to ride in the shades as much as possible.
    I would say, getting between 50% and 100% during your ride was a coincidence. You can't expect such high results all the time.
    To be clear, I am still running v9.30.
    So far, only  has done a valid, repeatable test.
  • It also depends on the orientation of the device in relation to the position of the sun. During a hike / a bike ride, the watch is not always exposed to the same sun intensity (forest / shade etc.).
  • Is it then possible to use firmware 10.00 to choose whether the battery widget will display either the remaining runtime in days or percent? So far you can only display the days.
  • No, to see percentages you have to press longly to menu button and wait a second
    0 Former Member in reply to KarsiyakaRocks
    I am running 10.0 fw on my solar instinct, even after reboot I can't see any percentage when I press long on the menu button, it only show remaining days, I do not understand why. Any hint ?
  • After going to the first main menu, wait 2-3 seconds and you will see the dial in the top right corner change from days to %.
    Hope this helps!
