The release notes for the recent firmware update (5.1) for the Explorer/SE+ notes 'Support for forwarding text messages'. I cannot find any additional functionality in the UI on the device, is this feature documented anywhere?
Have not tried this. I would look somewhere down the path of displaying the "details" for a received message. There is no telling which "level" this appears at - but I would look around the point where "reply" is available.
I've drilled down to every level of message display that i can and cannot find a change, but if anyone is successful please post.
OK, you made me look. Main Menu > Messages. Select thread, check mark. Select message, check mark. Hamburger menu, Forward.
Arrg, right you are, thanks! I hope this thread helps someone because it will probably take Garmin about three years to get around to documenting this. ;)
