Mini 1 user still going strong - the Mini 2 looks an even better iterative improvement, significantly so in terms of battery life - however for my primary purpose (ultra race tracking) I'll continue with what I've got until something else prompts an upgrade.
I run mine in extended tracking mode with 10-minute send intervals, which generally works well. Every so often I manually turn it on and check the "last message check" was less than or close to 10 minutes ago, confirming things are working properly. Occasionally it will be a bit over this, usually a result of poor satellite reception conditions, and I keep an eye on it and it sometimes sorts itself out shortly. If still nothing say 30 minutes later, or the last message check was several hours ago, I simply manually power the device off then back on and all is good again (auto starts a new track, immaterial in terms of the onward link to the race tracking website I'll be using).
In doing this off/on dance it obviously warns there's unsent send points that will be lost. In the spirit of getting things working again this is fine.
However, my question: when set to 10-minute send intervals, but unable to actually make the satellite connection for say 45 minutes, when it finally does connect will it send say 4 send points or just the one? Extrapolating this out, when it's been out-of-reach for several hours (eg. extended tree cover) will this be points every 10 minutes, or just the single point it's been trying to send for all this time? In other words, when I resort to a manual off/on, am I throwing away just a single send point or many?
I've come to the conclusion 2 out of 3 such times the device seems to get "stuck" and my manual off/on intervention is necessary to a) get things transmitting again and b) not have the device excessively draining its battery constantly trying and failing to send. Yet sometimes the transmit failure is indeed just a coverage issue, and even rebooting it doesn't get things working again until sometime later. Just trying to figure out how keen I should be to try this manual intervention, ie. is it a nothing to lose situation or am I throwing away multiple send points?
