Blackout affecting Garmin inReach devices
Hi all,
as almost everybody is talking about blackouts these days for the upcoming winter (at least in Germany), i was curious if a Garmin inReach device - specifically the new Garmin Messenger device - will allow me to communicate over satellite even when there is a blackout for several hours or even days.
The communication between two partners should be from one to another via direct satellite connection in between.
But what if a blackout turns off all servers on the ground? Will communication via inReach still be possible or does this require proper electrical conditions on the ground?
If so, where (in which country) should no blackout occur so that communication is still possible?
Really curious if the inReach (Messenger) is a good solution for what problem might probably come to us.
  • Please provide an accessible link to something which describes this. Those of us in the US don't know what this is about.
  • You should be able to communicate with your inReach device, activate SOS, and receive emergency/rescue services during a blackout.  Germany has laws that require critical infrastructure be protected.  But as with any technology designed by humans, nothing is ever guaranteed 100% unfortunately. See link below.
    www.bmi.bund.de/.../critical-infrastructure-protection-node.html;jsessionid=FC2686AEDB180A20FAEFA7A068497EE8.1_cid332
  • If this is referring to the power grid, inReach coverage is not affected as long as your device is charged. If the grid outage is long enough, you might need a power bank to recharge the device.
    There ARE ground stations involved in the Iridium network. I suppose it's possible that a ground station in a blackout area might be offline. The Iridium constellation forms a mesh network. Messages are relayed from one satellite to another as needed to reach a ground station (or the vicinity of a receiver). I don't know for sure, but it seems like this SHOULD make the network resilient when a ground station is temporarily out of service.
  • thanks for the explanation. For sure the iridium network will be online, as US military also uses that. But what about Garmin Servers? I mean the inreach messenger platform requires a valid subscription, which needs to be checked. This for sure requires not only Iridium emergency power supply but also Garmin server emergency Power supply, right? Also, the text message Service is very likely routed not directly between two people and the iridium satellites, but requires a connection to the Garmin Servers. At least that's how i would understand it. I doubt, that those Garmin servers have emergency power supply.
  • All communication between an iR device and ANY destination (SMS, email, another iR device) is routed through the Garmin servers. Even iR to iR device traffic does not travel directly over the Iridium satellite network.
    Some message destinations, such as email and SMS, require operational non-Garmin infrastructure. For example, email requires a working Internet connection. SMS delivery requires a working SMS gateway in "the general vicinity" of the recipient's cell provider. And, of course, working cell towers. This affects end to end communication independent of the Garmin infrastructure.
    I BELIEVE that device activation is recorded in the Iridium infrastructure, as well as at Garmin. I do not believe that the Garmin servers must be online to check to see that a previously activated device has a subscription.
    Garmin web sites (such as explore.garmin.com) are fronted by a content distribution network provider (Cloudflare, at least in the US). These ought to be solidly reliable even in the face of localized power outages. Still, the back end web site must be up.
    There are a number of components to the iR service. Availability is tracked individually. You can see the list of components and current status here;
    https://status.inreach.garmin.com/
    I have never, ever seen an outage for SOS. Like everything else, this depends on core Garmin servers. These would have to be massively reliable. Peripheral services, such as activation/deactivation, single sign on, weather forecasts, etc. are less reliable.
    I have no real idea (and cannot find out because Cloudflare is in front) where the core Garmin servers are located. But they, as well as backbone interconnects, must be reliable. I would expect that messages (between iR devices and the Garmin servers, not necessarily end to end) and sent track points would be as reliable as SOS. As a back country user of a safety device, that's mostly what I care about.
    This is really all related to standard practice for a high-availability data centers. You always have redundant power sources (local grid, plus generators if needed), at least 2 (and sometimes more) Internet backbone connections, redundant components and/or redundant server clusters, and so forth.
  • nice explanation twolpert
    one has to look at the iridium communication in different levels. To be accepted as part of maritime GMDSS system for example, Iridium had to build up lot of redundancy worldwide first. There are some services they have to organize the delivery too and for maintaining such services they are paid even when no payload traffic is generated.
    This is not valid for private communication networks like inreach. They deliver it if possible, but they will not build an extra communication network to handle such traffic. This has to do the customer (~Garmin) himself.
  • RE: SOS Messaging, Garmin posted notice of a one hour twenty seven minute outage (between 10:50-12:17 EDT) that occurred on Oct 25, 2021. Please see copy below:
    Iridium Messaging Delays
    Incident Report for Garmin inReach
    Resolved
    The networking hardware issue at our hosting provider has been resolved. All queued messages have been delivered and services are back to normal.
    Posted 1 year ago. Oct 25, 2021 - 12:33 EDT
    Update
    We are continuing to investigate this issue.
    Posted 1 year ago. Oct 25, 2021 - 12:17 EDT
    Investigating
    Iridium messaging is delayed due to an outage with our service provider. Some Email, SMS traffic will be delayed.
    Posted 1 year ago. Oct 25, 2021 - 10:50 EDT
    This incident affected: SMS/Text Communication, Email Communication, and SOS Communication.
