I've got a multi-day / multi-stage enduro later this year (hopefully), standard requirements: stick to prescribed route, carry a satellite tracker set to ping every xx minutes, submit GPX evidence of route taken on completion.
Plan to use my Edge 1030 for nav and recording, with an InReach Mini for satellite tracking and hopefully backup recording (1 second) - I have some question on the latter for those more familiar with the unit than me (only ever used it as a tracker / emergency SOS provision):
- Presume the InReach Mini can do this type of 1 second recording, ie. results in the same type of accurate GPX files similar to an Edge/fenix etc?
- Impact on battery life - ideally I'd like to be able to get 2 or 3 full days riding (12+ hours a day) without having to worry about recharging (will be carrying a battery pack so can top-up overnight / on the move if need be)?
- How are the GPX files broken down? ie. if the first stage was over 3 days - switched the unit on first thing day 1, off at the end of the day, then on again at the start of day 2 etc - would this result in a single GPX file or 3 separate GPX files? More out of interest - fingers crossed I won't actually have to use these backup files, plus there are plenty of tools available to split/stitch as required.
- How are the GPX files taken off the device, is it possible without using a computer? ie. smart phone app, in a similar way to Garmin Connect for the Edge.
I'm toying with the idea of also taking along an eTrex 32x for backup navigation and backup recording, though swaying against it possible: one less thing to carry, to worry about charging, plus will have my phone for backup navigation in a pinch. So my current thinking hinges on whether I can rely on the InReach Mini for backup recoding..?
Thanks in advance.
