Setting HR Zones Based on LT1 and LT2
I had my LT1 and LT2 zones tested for.  My LT1 is at 132 BPM and LT2 is 172 BPM with a MHR of 188 BPM.  I'm in Garmin Connect and selected Lactate Threshold and I want to make sure the attached values are all correct.  Can someone please verify?
  • Zone 4 corresponds to (anaerobic) threshold which is LT2. I think your LT2 should land squarely in the middle of zone 4.
  • In addition to what said, I would put LT1 as the lower limit of zone 2. So the left column would contain the following values
    XX (you can put any value, mildly higher than your RHR, for example RHR+10 - it doesn't really matter)
    132 (LT1, which is 76% of your LT2 - Joe Friel recommends 80% for start of zone 2, so 76% is ideal )
    155 (90% of LT2)
    163 (95% of LT2)
    182 (106% of LT2 - note that LT2 @ 172bpm is the average between bottom limit and upper limit of zone 4)
    188 (upper limit of zone 5 is your MHR)
    If you train using HR, you could also set up your heart rate zones to eliminate zone 1, and insert a sweetspot zone to cover the 95%-99% range of LT2. In that case your zone 4 would start at 100% of LT2.
    My recommendation is to train with power, and to incorporate the sweetspot zone in your power zones, rather than in the heart rate zones (because HR lags anyway).
  • Z1: 100 - 120
    Z2: 120 - 132
    Z3: 132 - 172
    Z4: 172 - 180
    Z5: 180 - 188
