Is anyone else having issues saving settings via the Phone apps??
I can download and install + uninstall via the Connect IQ and GC app but when I try to save settings it does NOTHING. I can change and save settings directly on the watch just not the Phone apps(Android) ....
Now most will say whats the issue.. Try change Watchface settings on the watch... Unless it is the default ones YOU CAN'T... Same with unlock codes for some apps,widget etc and also ALL apps for notes require the PHONE for input this is the same for ANY app where you input data on the phone and save to the watch such as the orienteering and GC apps. Now they are DEAD due to the issue.. And this goes for anything new I may wish to install too....
So to conclude. I can save and change most settings directly on the watch. BUT any thing you try to save on the phone fails, the save button does not function. BUT It is worth noting changing GENERAL watch settings such at time format, sound etc works fine.. This issue is ONLY effecting IQ apps
I have done the following also
Uninstalled BOTH apps and reinstalled latest versions(as was installed) as until a day ago they WORKED FINE. I have also downgraded the apps to previous versions and still no difference. I have tried using a different phone also.... I also have done a format and reset and FULL factory reset and no difference.
Unless you guys no of anything different to try. The only other conclusion is the issue is with GARMIN and their frigging servers yet again.
