Is there a way to display % of Max Heart Rate on my fenix 5 while I'm running, biking?
Hello, basically, if you want to display metrics during an activity, you can set them up. As far as Max HR percentage is concerned, you can either display the HR screen in your activity setting (read manual) and rely on the HR Zones (which are different % of max HR) or setup a screen with HR metrics and especially you can add the % of max HR and even average % of max HR.
Thanks Richard. I want to " setup a screen with HR metrics and especially you can add the % of max HR and even average % of max HR." as you noted is possible. I was asking about how I do that. I can display the zones in accordance with the manual--just can't view a percentage
You have to create a data field screen (please read your manual). Here's some screenshots to guide you (the gif should be animated).
In this example, I edited my Running (it's an activity name, not a sport type) activity and added a new 3-fields screen.
You then can add HR related metrics.
