En mi Fénix 3 Zafiro HR el altímetro, barómetro y temperatura dan valores desorbitados que no se corresponde con la realidad. A qué es debido? Cúal es la solución?
I am sorry your Fenix 3 HR has sensor issues. What you are describing is a hardware failure of the sensors.
Have you calibrated the altimeter & barometer? https://www8.garmin.com/manuals/webhelp/fenix3/ES-XM/GUID-2DF9C415-2A35-48CE-B20B-013DAA3358A5.html
Also, do you have the Garmin Express software installed on a computer to update your watch to its latest firmware version?
Hi,
Thanks for your answer. I have done everything you say, but It doesn't work yet.
Could be a hardware problem? If It was, what could i do?
Thanks a lot,
Iván
Yes. I do believe you have a hardware issue and your sensors have failed. You can reach out to your regional Outdoor Product Support to go over any possible options.
