Hi, my garmin fenix 5x can't recognize the cards, it can't update them via garmin express and maybe for this reason it constantly connects and disconnects to the computer
If your watch is having a connectivity issue and you can see it connecting/disconnecting, your will end up with a corrupt map or a non-working watch if it disconnects at the wrong time during the map update process.
- Clean the rear contacts on your watch - Cleaning the Battery Contacts on a Rechargeable Garmin Watch.
- Check the end of your charging cable to ensure all 4 pins are straight. You may need a new cable.
