Forcing ANT+ over Bluetooth on external HRMex
Hi,
I recently bought an Cycplus HRM H1 (optical) to wear om my arm instead of the chest strap.
The cycplus sends out Ant+ and Bluetooth.
My fenix5 only finds the bluetooth signal. And it isn't stable. (useless actually)
When I connect the Cyclplus with my phone (bluetooth) it works a lot better. Almost good.
When I connect the Cycplus with my Lezyne bike GPS it connects with Ant+  (because I can choose in the GPS Ant+ or Bluetooth). Then the Cycplus work perfect. (almost as accurate as the HR strap)
It seems like the Cycplus work good, it just isn't compatible with Garmin. But a Ant+ signal is a very basic signal. So it must be compatible on the Garmin, if I could only force a connection with Ant+ over Bluetooth.
Or is there a third party app to install on the watch that gives more possabilities?
Cycplus support is non existent.
  • both ant and bluetooth use the same 2.4ghz frequency and probably the same antenna/radio in the fenix
    but the fenix5 notoriously has a weak/bad antenna problem, stryd actually had to improve their pod somehow to deal with it
    however it still could be a software bug on either side, either the garmin or the cycplus
    there is a garmin app by a 3rd party that can record a HRM ant device seperately to the FIT file, maybe see if it can detect your armband since it's just broadcasting as a HRM
    apps.garmin.com/.../88ce4547-7d84-4289-b2c7-3e15ca00185f
  • Thanks. But the link doesn't work.
    I tried this one:
    Flexible data display from ANT data
    • FooBarEngineering
    But I can't get it to work. The display stays empty.
