Fenix 5 Sapphire bad GPS
I have a Fenix 5 Sapphire and I have a lot of problems with the GPS.
I run regularly and with friends and my watch seems to get the pace and distance wrong. The maps have regular zig zags.
I bought this in July 2018 prior to running the Berlin marathon that year.
Do I have a faulty one? Is it settings?
Many of my friends have cheaper Garmin watches and don't have this problem.
Regards,
Karim
  • Sounds  like it may be settings (first thing to check) - either your are using SMART or ULTRA TRACK
    General setting:
    Settings->System->Data Recording  has Every Second or Smart recording.  Check that this is Every Second.
    Under the settings for each activity (example RUN):
    Run Settings->GPS.  Here you can select the satellites in uses plus whether to use Ultra Track - make sure you are NOT using Ultra Track.
    0 Former Member in reply to razmichael
    I chatted with Garmin.
    I changed Data to Every Second. It was set to Smart.
    Ultra track was not set, and it remains at GPS normal.
    I was told the watch case material [metal] is more challenging in downtown areas.
    I will try every second. We will see how it goes.
    Thanks!
    Karim
  • Smart setting can certainly cause straight lines in your route.  You might also set the GPS to GPS+GLONASS (or Galileo) as having the extra satellites can help in an area with varied views to the sky.  Debatable about the medal crown - more to do with antenna, GPS Chip and software. Cities (with tall buildings) is tough for all GPS - some handle it better than others.
    I changed the Fenix 5 to every second and I'm still getting pacing issues and squiggles in my route. I don't see that in the person I was running with.
    I think the Garmin support person was right about the metal casing. I was asking what cases people with Garmin's have and most don't have metal. I'll try GPS + GLONASS.
    I'm thinking it's best to avoid metal cases on running watches. Today's route is usually fine. I'll see what happens when I run in a built up area again.
