Too much vertical gain and faulty barometer
Hi guys,
My Fenix 5x is going nuts lately.
Symptoms:
  • When I perform a roundtrip run the end altitude is way lower than the start altitude
  • The same hills look completely different during a run
  • Way too much vertical gain
  • Altitude graph shows downhill sections when there aren't any
Example:
  • #1 & #4 are the same hill I ran from each side
  • It's a roundtrip so altitude at start and end should be way closer
  • 'Start' to #1 and #4 to "End' are the same route, but look way differently
  • None of the hills has downhill sections in reality
This behavior started roughly 3 weeks ago and I can see it on every run activity. Different weather is not causing this. I don't observe that problem when I strap my watch on the handlebar of my bicycle as well.
What I did so far:
  • Put the watch on diagnostic mode. Barometer is fine.
  • Rinsed the sensor hole gently
How do I fix this issue? And is anyone else observing this issue as well?
Daniel
