I started to use online cycling with Elite Direto and Zwift some month back. When I use Garmin 5x simultaniously it shows much Higher speed and distance than what I get from Zwift (the correct values). What schould I do???
Alf
Alf
The wheel circumference for your Direto "speed sensor" shall be set to 173 mm in the sensor details on your F5X. Then you will gett "correct" speed and distance values on your watch.…
Sorry not the same answer.
I have a watch 5x same as above and so it gets its information from. Zwift direct not on the turn of a wheel like a garmin computer
That's why I don't understand how it's different…
I have fenix6 pro and I used this hint and ... it worked. However within one hour drive DiretoX showed higher distance about 500m (using Elitte application) than fenix also speed was a bit slower. Maybe…
You can find the answer here https://zwiftinsider.com/garmin-zwift-distance/
Mvh / BR Jocke
This is even more important when you use ERG mode.
Once Garmin does not have an option to calculate power based speed (for an indoor activity) either or trainers manufactures should broadcast it or Garmin should allow True up from files coming from Zwfit, Sufferfest, and others.
That's why I don't understand how it's different eg 130mph
No app (Zwift, Sufferfest, etc) brodcast any signal.
They come from sensors installed in the bike or from the trainers.
as far 130mph reading should be a spike or some interference.
regards,
Stig
I have fenix6 pro and I used this hint and ... it worked. However within one hour drive DiretoX showed higher distance about 500m (using Elitte application) than fenix also speed was a bit slower. Maybe circumference should be set to 174 to be more accurate? How is derived 173?
Elite suggests that set 190mm in wheel circunference. http://forum.elite-it.com/viewtopic.php?f=34&t=294
I agree with that figure tho' it's hard to figure out why it's such a small number.
My f5 still under reads the power tho'.
