After 15.0 update battery is terrible (6% in 3 hours) and now there's a huge lag to open a menu / settings from the 3'rd party watch face (Gearmin),
If I remember correctly, same issue was 1.5 years ago, now it's again here.
Is anyone seeing a major increase in the amount of activity calories the Fenix is now tracking after the 15.0 update? It seems like I’m over by a 1,000+ tracked activity calories above my normal.…
So it's about 7% in 16 hours, 0.5% / hour. Do you use 3rd party watchface?
Thanks
Tried to reinstall / install - don't see any improvements and still see lag of 1.5 sec to enter the menu.
I was seeing battery drain initially too, I've since soft-reset it by holding the power button down, uninstalled and reinstalled my 3rd party watchface, and so far all seems to be back to normal.
Did a long run without any 3rd party watch faces installed. Battery drain seemed normal. Going to reinstall one of the watch faces and see how theb performance goes.
Without 3rd party watchface battery drain seem to be ok, but if I'm installing any 3rd party even from Garmin , I starting to see how batter drains faster (twice at least)
Is there an option to revert to 14.20?
5% in 24hrs.
Haven't done any gps logging or ANT/BLE connections other than syncing with the phone.
No 3'rd party watch faces either.
But then again, haven't had any real drain issues on any s/w version, official or beta.
Same issue, lag in menu and terribile drain...
What has happened to 15.0?
all gonne...
regards
I have the same issue. Post software update to 15.0;
There is indeed an issue with "SMART" sync or watch face as my watch is pretty much drained out.
I've restarted the device and found that it perhaps the culprit might be the only two watch faces that I have. Uninstalled one of the graph based fancy ones.
Will update the watch face (which I did and it doesn't help and the lag does not occur if I use stock watch faces) but then again what is the point of a 1000 $ fitness watch if I cant have my own watch face
After my update I have a totally different watch face that seen before. when I hit any button besides the light button, the watch turns off. I am not able to connect to Garmin Express. I get an error about not being able to connect to servers. Anyone else having same problem? I have not been able to contact Garmin about it yet. They have always been good to work with.
