Just updated my watch to 15.0. Ran 3 miles on the treadmill and the calibration option is missing when I save my run.
Guess that's one way of "fixing" it... 1 step forward, 5 steps back with each update. It's unreal.
Did You check the versions: WiFi, BT, GPS....? Updated?
What would that have to do with anything related to the 'Calibrate' function missing?
Can anybody else confirm this?
Just serious!
Die You Look, If the "Auto Calibrate" for the foot pod ist enabled or disabled?
It's on auto calibrate.
Hello,
Can you confirm if the watch has been previously calibrated in the past? If so it may give the appearance of missing Treadmill Calibration. To calibrate after the first-time calibration you will want to run at least 1 mile then scroll down through the options and select "Calibrate & Save". Can you let me know if that works for you?
Reference: https://www8.garmin.com/manuals/webhelp/fenix5/EN-US/GUID-86541696-B60E-44BC-9A46-4349C86A1CD8.html
It has been calibrated in the past. In prior sw versions, the "Calibrate & Save" option was always available when I went to save my treadmill run. Starting with 14.20, it stopped appearing and it's still not available in 15.00. I ran 3 miles on the treadmill yesterday and that option was not available when I went to save the workout.
Thanks HarryC88,
Are you by chance using a footpod? I ask because the option will be missing using this accessory. Must also be using the Treadmill activity (Run Indoor doesn't count).
