Auto pause in hiking activity
If I enable auto pause with the When stopped setting in my hike activity, how does the device determine that I am not moving ? (Knowing that even standing still, my position changes from gps drift) .
also, it does happen that when moving again, the device does not automaticLly resume recording for a while (several km)
lastly, why is it that we cannot set the minimum speed below 1.6 km/h when setting auto pause to Custom. When snowshoeing in deep snow, speed is sometimes very low.
thanks for clarifying this for me.
  • I only use auto pause for sports/activity such as cycling. One is just moving too slowly I found. Hiking for example, and even trail running, if stepping over obstacles. and on switchback turns would always pause and re-start (and with delay as gps locks). For running and hiking I just pause manually if stopping to talk or look at a map. Regardless of what you do you still have a listing for moving time and elapsed time.
  • Thanks for replying. About moving time, how does the device determine the time you are moving and the time you are not you moviing slowly is considered stopped time. I would assume moving time is underestimated which would make moving speed overestimated.  You are right, overall time is always good and with overall distance you get a reliable overall speed, inlcuding stopped time.
    thanks
    0 Former Member over 4 years ago
    Indeed, I saw that one too. I mean the auto-pause is a perfect feature, but as rdeletoile already said, it is not working correctly when moving slow. Or that it works until a pause and does not restart again when the move in the horizontal line is slow. I saw this too in hiking as well as trail running mode. In very steep terrain or the underground is difficult to go, then the activity pauses. I cannot understand why this happens, as there are still steps recorded or the altitude goes up (even if there is only very little move in the horizontal line).
    I would say there are enough sensors integrated to determine if the activity is still ongoing or not. Hopefully there will be an update which fixes this issue.
