Hi Guys,
Does any body know if there is file name size limit or if we can only drop one .fit file in the Garmin/NewFiles folder at the time?
I have sent some waypoints and one track using Basecamp and also I copied a .fit file directly in the Garmin/NewFiles.
Turns out everything was fine but the course in that .fit file.
A later check showed me that the .fit file was still in the NewFiles folder. It was not processed by the watch.
So I change the name of that file and copied again into the NewFiles folder and vu à la... it worked.
I didn't change the course name inside the file but only the file name itself.
The original name that din't go thru was "Mairipora_Portao_Palmeira_Salario_ColinaVerde_Pinheiro_Azul_0002.fit".
Either it was the size of the name or because I was sending other things together thru Basecamp.
Thank you
