So far 14.20 has been positive for me with the battery. Doing spot checks shows it back to .3 percent per hour and staying consistent.
Still 6% in 6 hours.
I can't believe it takes Garmin months to figure out the problem.
I even got a replacement a few days ago, when contacting the support regarding the problem.
With that performance…
Update: 100% at 8.00 now 95% at 16.00
Wiyjout any activity or GPS, only HR.
Not OK at all. Incredible.
Exactly the same as with everything turned on.
I tried every combination. Even hard reset and skipped coupling to the phone.
Always the same result, 1.3/h.
I have OHR always on and track activity always on
What is your SNS version? Mine is 6.90, GPS 2.50. Charged to 100 % at 01.00, today at 17.00 I have 91%. That is 0,56%/h
SNS 6.90
GPS 2.50
BT always Off
Sync once per day
Light 8sec at 10%
Original Garmin Watch Face
Turn Wrist Off
OHR always On
Track Movement always On
Move IQ Off
Just HR widget
Almost everything the same. Move IQ - On. Don't know how it drains battery.
So today in 24 hours I have 12% drain - 0,5%/h only in watch mode. Not good.
In 24h lost 10% with 2 rides (total time 40m)
in the 2 rides it spends 4% (2% per ride)
Chest HR and GPS+GNSS
2 IQ fields
For me it's the same.
I think the problemm is the new sensor hub
5.7% per hour with walk activity standart gps on and ant+ HR Sensor
Battery drain here as well. But what I do not understand, how is it possible, that some pieces do suffer from it and some don't ?
I have bought a refurbished S/N 536289x which has got the rusting pin issue. It was replaced by Garmin with another piece quickly, S/N 536332x and suddenly I have to deal with battery drain which I didn't even knew about before? How is that at all possible?
The watch came with 13.40 - drain. I have updated to 14.20, did a reset, still drain. Confusing and unacceptable. A watch that should hold 14 days can't even make with 3 days...
Garmin, please fix ASAP.
I deactivated the heart rate monitor. Now the battery works 3 days. With heart rate monitor the clock consumes 2-3% per hour. Hello Garmin, is that serious? I'm disappointed!
Try new 14.72 beta. I installed yesterday and looks good so far. You have nothing to lose. In worst case you can downgrade to 13.40 which is considered as quite good one as for battery.
