Hi All,
I'm running a Fenix 5 on the latest firmware and yesterday I completed the 3 Peaks Challenge in Yorkshire (UK) using Ultra-Trac for the first time. Normally I use GPS+Galileo but I was concerned the watch battery wouldn't last the full duration. Now, everyone who does the 3 Peaks knows it is 40km in distance but when I had finished I had a reading of 60.47kms - despite not straying from the path. I then checked the gps map this morning and saw how in-accurate the readings were.
I wanted to check if the extra distance is because of the 3d distance option I had activated or because the GPS is not working as intended? I find it hard to believe that its a software issue given that it's so loudly lauded by Garmin.
Weather was cool and cloudy to hot and clear skies, no tree cover to speak off. GPS signal was string all the way through out. In short I think the error was mine and I am hoping someone with experience can advise me how to get more accurate readings - I'm hoping to go again next month!
Thanks in advance - AKS
