In the past few weeks I have been experiencing some problems with the installed widgets on my F5X.
It seems at random times seemingly when syncing with Garmin Connect, the widgets re-set to a certain pre-set arrangement. The Steps widget is automatically added and the notification widget is removed and the order of the installed widgets changes.
Has anyone come across this issue? In the past when this happened I used the Connect Apps to add and remove the widgets and re-order them back. This last time I did the add and remove and re-order on the F5X itself to see if it makes a difference.
