Installing Topo Pro maps?
I just bought Garmin Topo Pro 4 maps for Finland. Made sure, that both my Fenix 5x and Edge 520 Plus were listed as supported devices. I followed the installation instructions and the installation failed as there isn't enough room on the Fenix 5x.
I have only the default Garmin Topo and Cycling maps installed, no extra maps from Garmin or 3rd parties installed. How do I get the Topo Pro map installed? Please tell me that I didn't just throw away 200eur.
    0 Former Member in reply to TrippyZ
    It doesn't say, but I searched around the net and the Topo Pro map might need 2.6BG of space and there is 1.47GB of free space on the F5x with the factory supplied maps installed.
  • i am not 100% shure, but as a read somewhere, the cycle and the topo-active map are the same.
    Best way i think, is to copy for example the cycle map with all the lizenz files to a computer and the delete it from the watch
    0 Former Member in reply to Mistamb
    This seems like an interesting idea. I would need to figure out the naming schema that garmin is using that I will delete the correct file.
    As far as topo-active and cycle maps being the same, at first glance (using BaseCamp) it seems to be the same. Having said that, I have seen reports where car navigation works only with topo maps enabled and fails with basicle maps enabled. Hard to tell if they are identical or not.
  • i think in basecamp (don't use it) you can right click on the map properties and it gives you the file-name to the map name. car navigation should works with topo-active maps, anyway it does not work on the 2019_10 version of the maps) . don't know about the cycle maps.
  • I have the same Topo pro 4. You can actually remove from watch either south - west topo or sout-west cycling maps because those are not needed in Finland. Check from basecamp what are the file names that you can remove.
    0 Former Member in reply to jarivee
    Thank you for the advice! The problem I'm having is that I can't find the file names on BaseCamp. I'm using the latest Mac OS version of the BaseCamp.
    I can find the list of the maps and when I click the "Revel in Finder" (same as Show in File Explorer on Windows), the Finder window only shows me the Root folder of the watch, which contains the Garmin folder. So at the moment, I've yet to figure out how to delete the cycling maps that should free 4GB from my watch.
    0 Former Member in reply to Former Member
    After calling the Garmin support and finding the Garmin cycle maps files (based on their update and creation timestamps) I managed to remove them. This created enough space on the F5x to install the Garmin Topo Pro maps.
    It will be interesting what happens when map updates come around as Garmin Express still shows the Cycle maps as installed, but doesn't show the Topo Pro maps as installed.
    EDIT: I would urge Garmin to go over the supported devices list for Topo Pro maps and remove devices that do not have enough storage space to fit the Topo Pro maps (with the default maps installed).
  • But in principle it comes down to the point that we need a more elegant map installation mechanism to decide on our own which parts of the maps are to be installed on the device when filesize does matter.
    - display device map files in app (garmin express or explore )
    - customization of device map files (at least switch on/off complete map types (cyclemap..) and regions (e.g. north/south).  (Garmin express)
    - in app (garmin express or explore? Connect iq 'store'?) license management (add e.g. north america region license for europe devices, list additional topo maps)
    - reserve space for private map files (i like the open topo maps a lot because the routing algorithm for e.g. walking / shortest way search can be applied far better than on the bicycle optimized maps that never give you the shortest path)
  • I know what happens, update fails. Been there, seen that. When update comes available, you need to remove topo pro till update is installed and do the removing south-west maps + installing topo pro again.
