Hi guys,
On the watch, one can choose whether to let the watch calculate one's maximum heart rate and Lactate Threshold automatically or enter one's own values manually. However, I can't find any documentation, neither from Garmin nor in this forum, on what's preferable? I have NOT done a lab test of my values, yet I've always set them manually and here's why;
The auto heart rate seems to use the old 220-age general rule for it's calculation, as I'm 46 that would put me at 174 as my maximum heart rate, which to me seems a bit low, as I have several sessions where I've gone into the 180s or even 190s as my max recorded rate? So my questions are:
1. Will this value be updated over time? Let's say that it puts me at 174 and then let's say that I record 5-10 sessions where I surpass that during a season, will it be bumped up to reflect the real value?
2. I've read the FirstBeat Whitepaper, but I can't find any information on how much the maximum heart rate affects the Vo2Max calculation? For example, I now have my watch set at 190, if I drop it down to the 174 suggested... would that mean that my Vo2Max would also drop from the present 46 to in the 30s somewhere as the obvious effect of dropping the max heart rate would be that what's now a Zone 3 run will become a Zone 4 run? Which I guess could be seen as my fitness being worse as I'd be closer to my max heart rate?
I probably should add that the 190 mentioned above is a pure assumption. But I have some time somewhere read that if one tries to do a manual max heart rate test, your brain will actually make you stop some 10-15 beats under the real value as a self-preservation thing? So if I run up a hill and down again a few times, I feel miserable after a while and max out at 176, but if someone would be there putting a figurative gun to my head, I would probably be able to push myself to 185ish or even 190?
Kind regards/Mike
P.S. I really did try to search forth and back in the forum before posting, but didn't find any threads of a similar character?
