Messed up order of widgets when installing apps/widgets
Hi,
has anybody else the same problem?
Everytime i install a widget or app, the order of my widgets gets messes up.
Sometimes apps are deinstalled or standard widgets are reinstalled, which is a little annoying.
Is this a common bug?
  • Yes, it’s an issue with GC and GE.
    Tip: Install all of your Applications and the order of them first, THEN work on your Widgets. If you make adjustments and/or changes to your Applications, expect the Widgets to revert back to the “stock” setup.
  • Hi,
    thanks for the quick response.
    So it seems I have to live with this issue.
    Also thanks for thr tip. However, this will not help when trying out new apps.
    Sorry Garmin but GCM needs a good sorting out. In another thread the inability to sort widgets in the app was touted as a feature (as you could use the small screen of the watch instead!) and this bug is ages old. Please get some QA involved, freeze on adding new features and get it behaving.
    I shouldn't have to go and sort my widgets out if I want to reinstall/delete an app - As a result I don't touch new apps on CIQ because it's a PITA
