battery life with wrist based hr off
Hi, I was wondering if anyone has any experience of the average gps battery life with the wrist based hr turned off. I would also be disabling Bluetooth and any sensors as well. The Garmin site only gives battery life with the hr switched on and I could imagine that the wrist based hr would be a fairly large drain on the battery. Any help,will be very appreciated. I will be using normal gps
  • Search through the forums as there have been many similar posts. Basically, WHR has little impact on battery life under any conditions.
  • The LED's are probably about 3rd in power drain, a long way behind the GPS chip, and the backlight (depending on settings). I haven't experimented personally, but certainly less than 1% per hour in exercise mode (and far less than this in watch mode, where the LED sampling frequency is lower).
  • Hi, I was wondering if anyone has any experience of the average gps battery life with the wrist based hr turned off. I would also be disabling Bluetooth and any sensors as well. The Garmin site only gives battery life with the hr switched on and I could imagine that the wrist based hr would be a fairly large drain on the battery. Any help,will be very appreciated. I will be using normal gps
    in my case, battery drain with WHR off, and BT off, is 4%/day in watch mode
    I use a belt HR during mtb: battery drain 25-30% /4h30m (gps+glonass)
