Lactate Threshold detection issue after reset factory
Hey guys,
I'm using the lactate threshold value with a HR4 strap since my FR630, and it used to work fine with my F5s as well.
I really like this stat and I find it relevant in training.
A few days ago, my F5S got stuck and I did a factory reset. Worked fine.
Then I paired my HR4 once again and went running.
A few workouts later, I noticed that the lactate threshold didnt' move, nor the heart hate, neither the speed.
It looks like it's a manual value...
Does any of you have any idea?
Thank you! ciq.forums.garmin.com/.../1432619.jpg
  • Have you been getting on device alerts about LT detection?
  • There is an ongoing issue that after firmware updates, the watch can import incorrect HR information from Garmin Connect including zones, LTHR, change of zone calculation method, etc. I suspect that your factory reset has triggered the same problem.
    Set your zone method to be %LTHR in GC and perform a sync, and then do a run that is likely to result in LT detection (ie. including sustained pace below, and then above, your likely LTHR). This should restore good HR datapoints to your watch.
    Thank you guys for your answers,
    I tried mcalista's suggestion today and ran for a 2x10' at treshold pace.
    It worked! Thank you very much!
    I hope these posts could be helpful for anyone in the same situation,
    Regards
  • Hi I have same problem upgraded from Fenix 3 to Fenix 5 then since My Fenix 5 (with HRM Run belt)  not geting LT detection, 2 test failed...
    Software 14.10
    ANT  / SNS 6.90
    So I'll try today solution finded on this forum:
    - I Deleted running & swimming  HR zones in my GC & fenix
    - how shall I set   HR max ? & LT ?  & LT zones in User Profile ?
    Then I'll try get new LT test today and see if that detect new Lt
  • worked but My LTHR detected is way to low 154 to previously 167 bpm what's impossible bcs since 4 weeks i get Fenix 5 I worked quiet hard.  that messed up my Vo2  HR zones based on %LT and pf course Training status = Unproductive
    If i Delete (export ) all workouts since New wrong LTHR
    than change my LTHR manually
    and upload my activities back it will recalculate with new LTHR set manually all metrics ?
